Hi y’all!
I run nac112/nap150/Flatcap2. All recapped.
Would it be worth the ”hazzle” as an upgrade to go nac152x/nap150x?
Best regards
Ron (Sweden)
You mean these? Doubtful, borrow and try at home if you can. (Or compare with your stuff at Akkelis, which one suits you best)
I doubt it - save up for a better pre amp (202 minimum). That will make a far bigger difference.
Yup, those are the ones. Need recapping of course.
I guess not to big a step up in musical quality if I read your reply correct.
Better go directly to the 5xx-set up Akkelis got …… will not make my wife of 40+ years happy…… but I will a verk happy husband
Cheers!
The 152 is a serious step up.
