Hy folks,
I have a question.
I have a XPS2 and an olive cdx.
Can I connect it?
Thank’s for help.
Yes, if you’ve got the correct Burndy cable?
I have a burndy with NDX connect to xps
Hmmm. There are several types of Burndy. I think a call to the expert is required. @Richard.Dane , we need you.
If it’s an S-XPS Burndy (look at what’s printed on the collar) it will work.
Also the “older” type XPS Burndy.
The “11 pin” variant?
Thank’s, tomorrow I check it
Hold on Nige, you’re on holiday!!!
I am here to serve.
How’s the beer?
Tasty.
Yes, no problem. Either the original XPS Burndy or the improved S-XPS Burndy will work.
Is it the same Burndy for a CDX and NDX (which, AIUI, Neder has)?
Thank’s all. I have sxps burndy
Then you’re good to go. Enjoy!
