Quick question regarding volume control via remote control.
Is it meant to be precise incremental volume adjusts with each up or down click? Or is it a ballpark movement.
The model I demo’d was pretty precise, but the one i received new in box less so.
Thanks in advance.
I find Naims control of volume via the remote or even app for that matter to be the biggest draw back and frustrating. It’s all hit and miss in my opinion, the old 272 was by far the best of all their amps I’ve owned.
Double tap and hold for precise movement.
