I use it. I know it’s there and what it does. Is there a “gets rid of irritating in-house advertising” button? ![]()
Not sure if I’ve understood your post correctly but if you mean the default initial list of displayed stations I found the only way to change them was to save the ones I wanted as ‘Favourites’ which seem to be a different list of ‘Favourites’ specifically for the Radio option.
They then display in alphabetical order on the initial screen though there seems no way to edit or move them manually.
Actually I think you have to play them as well. It’s more of a ‘Recently Used’ list but does appear to be alphabetical.
It just kept showing whenever I opened the app. Now, it doesn’t…
