Your cleaning routine
I was wondering how you all approach your hifi cleaning. How often do you, what do you use or do you let someone else at it?
I hoover weekly and have a nice feather duster which reaches under and in between equipment. I also use this with my turntable and lid (care taken around stylus).
After this I use the hoover with a brush attachment on the turntable around platter and tonearm etc, on the components themselves, especially the opening of my slot loading transport and finally around otherwise difficult to reach places of the rack.
I only use window cleaner once in a while on the turntable lid if there is a build up the feather duster does not remove.
I think (!) I am OCD but leave that for you to decide :slightly_smiling_face:
Must admit that whilst I hoover around and under it I rarely move the rack forward. Usually only when I need to sort the cable salad out and/or plug something new in. It’s a complete PITA to move it forward and back. There is little space behind it and it’s spaghetti junction.
Daily light dusting with a microfibre duster. If any marks/deposits noted then wipe off with a cloth lightly moistened with weak detergent solution (washing up) liquid. I’ve always followed this regime. I would never use any kind of household sprays or even specialist electrical foam cleaners or the like for fear of causing damage or leaving behind deposits which may be difficult to remove.
I did look at a dust cover for the lid on the turntable but thought there was more chance it would leave micro scratches so didn’t bother. Use decent light duster wands that I found from others on here.
Occasional dusting with a microfibre cloth is all my electronic stuff gets. Speakers get an occasional wipe with a microfibre cloth with some wood polish sprayed on it. Occasional in this regard most commonly means anywhere from fortnightly to six weekly.
ACHOO!!! Sorry!
Lately, I wait until after it’s so dusty you can write your name in it and only get cleaning when the rack is literally draped in the first dozen cobwebs.
A static feather duster type wand used every so often seems to do the trick
Every 12 to 18 months I do a complete breakdown of everything.
This means taking what is possible to dismantle as far as it can reasonably go.
Then with a thorough going over the floor plan.
Using Nordost anti static spray, kontak cleaning liquid and copious amount of kitchen paper.
Face, foreskin, rusty sherrifs badge - always in that order.
Settled dust isn’t a problem, just airborne!
Yes - I was thinking of the clouds of dust generated when you use a duster! Only kidding though.
Do you re use your flannel or is it single use?
Timely thread.
This just arrived:
So I have just given it a ā€˜deep clean’ using these:
Great end result and I now also know 99% of any bacteria that was there is no more.
On my main audio devices bought from new, soft microfibre towel and a drop of water only when necessary.
At least weekly with a Dust Magnet.
Decades ago, when adverts for a particular disinfectant or bleach (Dettol? Domestos?) used to say ā€œkills 99% of all known germsā€ I always used to wonder about the other 1%, and unknown ones…
Then bear in mind that in the right environment bacteria can double in number every hour or faster, so that 1% could be back to the original number in 7 hours or less… But of course surfaces of hifi boxes don’t present ideal environments … and in reality it doesn’t actually matter whether or not it has bacteria on it!
Not my flannel.
Full break down and clean every 6-8 months.
Accessible dust removed when irritatingly visible.
It’s more fun than just zapping it with thunderbolts.
Do you find it worth the price tag?
In the past 12 years or so I’ve used 2 and just starting a 3rd bottle.
I mostly pump a couple of spray on some kitchen paper to run through a cable or two, never directly on anything. Used sparingly it should last a while…. Nordost recommends using it every few weeks, but in my environment 12 to 18 months seems fine.
Nordosts speaker and other cables are not insulated. Dust and fluff build up contributes to static that makes a notable loss to quality, so the anti static spray 3X should be crucial if running Nordost cables IMO.
Ā£60 a bottle of snake oil is not bad compared to many others :innocent:
Thanks for sharing @TOBYJUG. Having almost only Nordost cables, I think it’s worth the stretch, especially if the effect is long lasting as you mentioned. My dealer never talked about this spray but I was aware of it. If there’s an audible effect, then it’s compulsory buying it. Where do you mostly notice this difference?
