I have come across a rather bargainous 250DR however it has a 115V sticker on the back which I believe implies it is a north american model – is this fine for use in the UK, convertable, or just flat out avoid? Thanks for any knowledge!
Yes it has to be converted to 240v by Naim.
Thanks Gazza - obviously 'll reach out to my dealer but does anyone have any kind of idea of likely cost?
Seller mentioned they had powered the unit on – is that likely to have caused damage if done on UK mains?
It was many many years ago, but when i had mine converted it did not seem unreasonable. Not sure on the powering up on wrong voltage, Naim will sort it and check it over before sending back.
Not a good idea to power it up on UK 230V mains if it’s still a 115V unit. I would ensure you have some guarantee or avenue of recourse with the seller should Naim find that any serious damage has been done.
I would give that one a miss, to be honest.
It’s certainly likely that powering up a 115V unit on UK’s 240V has damaged it.
You could use an external step down transformer, but that’s usually not optimum for sound quality.
I believe Naim has fixed price repair costs if they change operating voltage? Likely to be above the difference in cost of this US voltage amp vs a correct UK spec one.
I should look for another 250, they pop up every once in a while … connecting a 115V unit to 230V can really cause some serious damage.
Surely if you run it on 230v you could claim to have a Nap500?
Cheers all, I decided to stay away, there were some questions as to legitimacy in the first place, great advice from all
