I think I know the answer to this question but will ask in the vain hope someone much better informed than my self will have a clever idea…
Long story short I picked up a new 250 DR today but am awaiting my 282. Part ex’d my 200 in the process so no longer in my possession.
However, in the meantime my HiCap seems to have developed a problem (definitely the HiCap - tested all other outcomes) so I am left with 250DR / 202 and a napsc combination.
Is there anyway I can make this combo work whilst I await the 282 or fixed/new HiCap?
Are you sure the Hicap is dead? It seems a bit of a coincidence that it happened now. Are you sure the connections are correct?
Unless you have dismantled everything it should simply be a straight swap of the 250 for the 200, each using the lead that is supplied with them.
If it’s all via a good dealer, I’d not be surprised if you can borrow a hicap for the time being. Otherwise, a sh flatcap or hicap will get you going. An olive hicap unserviced can be bought for 300 gbp or a bit more.
Thanks ChrisSU - overnight Hi-Fi maths has justified a nearly new HC DR nearby should be purchased today as this will benefit my 282 with 2 x HC DR when it arrives!
Not good having a HC that is DOA.
My dealer worked out about 8 months ago the need to buy a lot of stock in covid. He says he never thought he’d be placing orders for 20 off ndx2s in one go!
I’d tread carefully. Many people find very little difference from a second hicap; I certainly didn’t on my 82. £1,500 is a lot to risk with no certainty you’ll like the improvement.
