We need pics🤣
A cheapish suggestion. Upgrade the Rega Planar 3 with the 24V motor and a Neo power supply, an Exact cart if you don’t have one. That will get the very best out of that turntable.
Yes, that’s a possibility, but I think I might just home audition an RP6 initially in an attempt to calibrate my thoughts and current experience with the RP3.
Not sure where you are based but I believe Darran at Class A offers these Rega upgrades. Just a thought.
lol. Where indeed would you put your feet
And Naim have provided a new set of Burndies which fit precisely as one would expect them to.
My very helpful dealer implied that Naim have reversed a ‘design change’ introduced to improve the Burndy connection - whatever they’ve done, it’s certainly working.
And, again, for anyone with the same issue with the NC NPX 300 Burndies, chase up your dealer for a replacement set.
ATB, J
