How good is the the analog pre-amp of the 222?
Has anyone tried connecting a Ndx2 to the 222 and compared it to the onboard streaming (without the addition of the 300 PS)?
Some have reported that the Nd5xs2 is a bit better vs the 222, as streamer/ dac.
You’re going to get varied impressions in different listening environments and preferences so you’ll need to listen for yourself and decide. I prefer the 222/250 to the different NDX2 fronted systems I demoed but these weren’t head to head comparisons. I just never got on with the NDX2 without a PS, needs a 555 imo. People will say the dac is better in this or that OC streamer but you really need to listen b/c the dac deployment and overall design in the NC is different and presents the music in a more spacious, focused, quiet, presentation that translates to a more realistic and musical experience in my experience. It’s quite different than the OC and some don’t get on with it so you definitely want to listen for yourself.
What I mean is will a better streamer such as an NDX2 or say a ND5XS2+Qutest improve the SQ of the 222 vs streaming from its own onboard streamer. Not using the 222 as a streamer into another pre.
Using the 222 as a stand alone preamp seems like a waste when you could just get a dedicated preamp.
be quite a bit better i would have thought, before i got a 252 supercap, i used my NDS with a 272 (the older version of the 222) and it was way better than i was expecting. i bet the 222 is better than the 272 it replaced.
i didnt run my 272 as a pre for long because i got 252 which is a whole new world
I second that, if pre-amp is what you need, then better just go for 332, needs a bit more budget than 222 but obviously better on analog section. Or get 252 if you prefer OC
Good question, I’ve been wondering about this as well. The 222 sounds very good, however I would be very curious to compare it directly to the NDX2. On paper the NDX2 should be better…
