What would give the best SQ. NSC 222+NPX300 or a bare NAC 332/ND5XS2/Qutest into active speakers.
ND5XS2 + Qutest into 222 beats the 222’s streaming easily after doing an extensive home demo.
Did you mean ’ into 332’?
Since the 332 is a better pre than the 222, even with 300 I think you have answered your own question😉
No, I meant 222.
I attached my ND5XS2/Qutest to the analogue in of the 222. Played the same song from Roon and switched between the analogue in and the streaming part of the 222.
I didn’t have a NPX on hand so couldn’t hear how the 222 would sound with that. Also never heard the 332.
I just wanted to be clear on what was being compared. A 222/300 is priced similarly to nd5 xs2/quest/332, so worth knowing that the latter is (as might be expected) preferred.
Interesting, thanks!
I thought maybe the NPX300 could improve the streamer section to a higher level than the ND5/Qutest hence my question
Also didn’t know a bare 332 would be a better pre amp than a 222 with npx.
Just seen your reply. It’s an interesting question as I am contemplating 222/300/250 and can’t afford 333/332/250. Going ND5 XS2/Qutest instead of 333 is a cheaper option. Or maybe Innuos Pulse/Quest.
Something to add to my January demo.
By way of an update, I’ll be bringing my January demo forward due to my XS2 left channel failure. So hopefully this or next week.
Whilst I’m sorry you’re having issues I am interested to hear about your demo.
I’ll be sure to post my impressions - my old ears (not as good as they used to be) and dealer’s much larger room.
Once I have decided my path, then I’ll arrange a home demo to make a final decision. Exciting .
Interesting, I’m starting to wonder whether the 222s real strength is its preamp. Did you try just the ND5XS2 into the 222?
Not yet actually.
Could be an interesting experiment.
Try the 222/300 with a PhoenixNET – yielded an excellent return with the integrated streamer/pre particularly if you use subscription music services. YMMV.
Home demo done! I’ve ordered a new NSC 222 and NAP 250 as they sounded good in my room with my existing B&W speakers. The NPX 300 was a good uplift too, more musical with better timing, but I will wait until I upgrade my speakers sometime mid-year. Shame!
