I am in the process of upgrading to 252/SC non DR. Problem is the SC does not come with a burndy cable. Can I use the one from my Ndac/XP2S (non DR) connection as a temporary solution ? Are those two burndy cable exactly same ? Is there a designated name(pin specific) for that SC burndy cable ?
Many thanks.
Existing setup
282(HC X2 DR/non DR one each)/250.2
CDS3/555PS(non DR)
Ndac/XP2S (non DR)
Absolutely. It’s part of the product. It’s not reasonable for him to say he’s keeping it. If he does that ask for £550 off the price to enable you to buy one from Naim.
Looking at the OP’s system he doesn’t currently own either a 252 or a Supercap but, you are of course right. He could be buying the SC from one seller and the 252 from another. Either way though he should end up with the correct Burndy for them to work together and not need to buy one.
Sounds to me he just needs to ask the seller(s) the right questions
To be clear…the Supercap is not supplied with a Burndy. The 252 can only be run with a Supercap and therefore comes supplied with the correct Burndy.
If you are buying the 252 and Supercap from different sellers it is the one with the 252 who should be providing the Burndy. It is effectively part of the preamp.
