Glad you enjoying your change. Yes the Supernait 2 is cracking but as you rightly say it isn’t fair to compare.
I can’t wait for you to hear what the 250DR brings, it genuinely doubles the size of the speakers and detaches the music from them.
As great as Naims combined units are, they are not a match on their Pre/power units in my opinion.
Definitely appreciating the 252. Much more delicacy and space around the instruments, everything just more defined and less frenetic.
The 282 is good, the 252 is better.
Hi @popeye. I can’t remember, did you add the 282 to your SN, or did you put the 250 in at the same time? I wondering which of the pre or the power has the most impact on the effects on the speakers that you describe?
No I did the two at the same time. So I can only go via my experience having done a few step changes over the past few years, qute to nova to Supernait to 282/250.
FWIW - my 282 was powered by my XS2 for awhile (while the SN3 was in hospital). The 282 was the major uplift I recall, even when I got the 250DR. The 250 certainly was superb in terms of presentation and bass solidity. It made everything more ‘solid’ and assured, but wasn’t the revelation the 282 had been over the SN3 (which, when healthy, I p/xed for the 250 - I was glad that I had it ready in due course for the 252).
I have always preferred the 252 over the 282. I can see however that the sheer verve of the 282 can be (superficially?) impressive and the 252 is very sensitive to set up. So I can see how some might be misled.
It’s now been several weeks since I replaced my 282 with the 252.
I’ve found the 252 to provide greater detail, clarity and separation leading to a richer more enjoyable musical experience.
Yesterday I was listening to Bert Jansch’s first album, one I’d listened to for fifty years, I’d have to say it has never sounded this wonderful. I now find myself listening to music for hours on end and being fully captivated by the sound.
The 252 is an outstanding pre amp.
I’ve recently upgraded from the 272 to a 252 and I find I’m struggling to control the volume and find the sweet spot. I have a reasonable size listening area and often listened to my 272 around 30-35 + and if that was a problem it was always easy to adjust, the 252 seems so loud and I find it difficult to adjust with both the remote and the app (automated) and not playing it above 8-9 o’clock.
I love the sound and it is a big step up from the 272 but I wished the 252 had the same volume mechanism as the 272.
Kind of makes a few that keep telling me that the pre amps don’t need an upgrade a little naive. Sound wise it’s true but features and functionality certainly needs a shake up IMO.
