I guess I’m just confirming that this isn’t supported at all? Just upgraded to 4.9. Checked the press release and it’s missing the usual caveats around not being supported on legacy streamers so I assumed it would be ![]()
The legacy streamers have hardware limitations that make it impossible, sadly.
You can get around the limitation.
Download BubbleUPnP and use that to direct Tidal/Quboz HD to your 272.
