@Woodford Picking your problem up again. Do you know which Virgin Media Superhub you have? Also are you connecting your 272 to your superhub by Ethernet cable or WiFi?
The reason I ask is that the Naim app on your iPad sometimes not seeing your 272 is likely because either your iPad or your 272 is losing sight of the WiFi and the discovery function of the app isn’t working properly consequently.
Just to not forget that this situation, the disappearing streamer, or server, happens very often to us , for a large part of us with the old platform.
For me, maybe 2 or 3 times per month, sometimes less.
A restart of the router, then a bit later the streamer, solves generally the issue.
FR is that only with the first gen streamers you see this, I think you have a NDS?
Out of interest when it does occur have you found just resorting the NDS clears it at all?
For the record I find the NDX2 with the current firmware I find it solid - never an issue - and there is no way I would want to restart the router in my house for various reasons, but I can’t now comment on first gen streamers. However I use an ISP (BT) router with a querier built in which optimises applications and services using multicast such as UPnP SSDP. I use Cisco and Ubiquiti switching and wifi products.
Hi @NeilS What does the following mean? Having problems with my 272 disappearing from the network after installing the new app, is this something I can use?
Reset system automation restores the system
automation settings to default. Clear all presents deletes any stored iRadio stations. Neither is related to network issues.
A factory reset won’t at all help your network problem.
What I suggest is that you turn the 272 off and also turn your router off. Then turn the router on again and wait until it has fully restarted. Then turn the 272 on again. I would restart the app at the same time.
