I think that’s what I said. The 282 is over the 300 head unit, not the 300PS…
well…. checked all cables and contacts but still, when i put balance to the left side, it appears like that loudspeaker is a “smaller” one. the music seems to be delivered through a cloth or gauze, if that describes it somehow?
If you swap over speaker cables does the ‘weakness’ move to the other speaker?
I had this a long time ago with my Kans (the left speaker remained weak even with a cable swap).
Cause was a tweeter at the end of its life.
hi steviebee, thanks for the info.
when i swap the LS cables at NAP, then the other LS becomes the weak one.
thats why i imagine it can not be a part of the speaker.
also it can not be the LS cable, as I had the problem with two different ones i tried out.
it more and more comes dien to beeing a problem with the 282 i guess ….
Is the issue with both sources, or just the NDX2? I had a channel loss from my NDX2, so you should test for that.
As per the OP’s opening post, the issue is there regardless of source.
sorry for the silence. i was away… thank you all for your input and help, very appreciated !!
i will need to go on and check the 282…
i guess that is what it comes down to.
thank you all have a good start into December 22 and best greetings!
