Hi all, just wondering if naim still have the little plastic rivets that hold the NAT03 case together. I’ve aquired a clean 03 tuner and one of the plastic pins is missing. If no, is there something that can be used as a substitute?
Thanks.
Is it just the pin itself or the whole insert and pin together that’s missing?
As Robert posts above, I’m sure @NeilS would know whether they are still available.
Its just the pin itself the insert is still in place.
I will check this for you.
Neil.
Thank you Neil, it is much appreciated.
regards
Mario.
Hi Mario, unfortunately it’s a no I’m afraid.
They were manufactured by Jet Press, part number BUR015 if it helps.
Neil.
No problems Neil, thanks finding out that info. I should be able to find something that will at least hold the insert in place.
Mario
