Just tried connecting my turntable to the my nac and the phono rca inputs won’t fit, middle bit too big, so obviously I need an adapter or change ends,
What am I looking for thanks
The NAC42.5 used 50 ohm BNC sockets. You could use 50 ohm BNC adaptors, but it’s best to fit 50 ohm BNC plugs to the phono leads.
Class A will fit RCA sockets so I assume Naim will too. If it’s not serviced then another reason to send it in.
Thank you,
Ordered adapters, serviced by naim this year thanks,
