552 lights again
Hi after rebuilding my setup…everything works the remote can control vol,balance and inputs etc….. except I cannot turn the display leds off….
I have tried powering down for around 10 seconds….but still dsp on remotes does not work….
Is there a min time duration to switch off???
I suspect you need to press the pre button the 552 remote. If so, I claim my prize.
Many many thanks worked :ok_hand: :+1:
Brilliant!
