Hello all
One of my friends cannot find the transit bolts for his NAC 552, so can the ones from ND555 be used instead?
hope some can answer this question
Hello all
I don’t know what size transit bolts the ND555 takes but the NAC552 uses 4 x M5 x 10mm.
There are longer bolts used for CD players and the Superline, so be careful!
Oh yes, and don’t even think of trying to move a NAC552 more than a few feet (very slowly!) without fitting the correct transit bolts, otherwise disaster is imminent.
