555ps
Good morning is anyone using 555ps with nss333 streamer and was it a big improvment
On a practical point, remember that should you go this route, you will need to buy two special leads:
they cost 1100 GBP total (2pcs needed).. might be better value going for a used 300PS.
I can’t say how a 555 works with a 333 but with a NDX2 it’s a colossal improvement, bigger soundstage, more insight, better vocal articulation, improved bass response etc. But that said isn’t the 300 the best match for the 333?
