Nice, is it AMD only or is there an Intel version?
I’ve been using Cooler Master something-or-others. Reasonably cheap and seems to work OK.
It comes with brackets to install over LGA and AM4 sockets; it is quite tall when installed, 165mm high so ensure your case has the clearance.
Noctua’s are really high quality, try one in your next build.
