Does Naim or other, make a 4 Pin DIN to XLR adapter so I could use my redundant 4 Pin Snaic Din cable with my NAP 250DR.
I do have the thin stock 4 pin Din to XLR cable that came with the NAP 250DR. The Snaic 4 is a thicker better quality looking cable.
I know Chord do make other option 4 PIN DIN to XLR cables for the NAP 250DR, I would prefer to stick with Naim but be able to use the Snaic 4 PIN I once used with my Hicap and NAIT XS2.
I’d have thought it better to have one made, or ask someone to swap the end of your thicker one to suit.
Any adaptor would surely introduce additional contacts into the signal path.
I do use Chord Epic Interconnects and speaker cable. I suppose I could try a Chord Epic DIN to XLR. Seems a waste of a good Snaic cable to not be able to repurpose it for use with my NAP 250
The stock DIN to XLR supplied with the NAP 250 does not look the same standard quality as the Snaic cables
You’re forgetting that there are more cores in a Snaic lead, both power and signal. If you were to strip a Snaic lead you will more than likely find the cores are the same as a Lavender lead.
Are you actually referring to a SNAIC or simply an interconnect. As others have mentioned, a SNAIC carries power and signal, a standard interconnect, only signal.
As you’re talking about connecting to your 250, I suspect it’s an audio interconnect?
They look different because they serve a different purpose. The din to XLR that comes with the 250 is ideal for the task, so just use it and don’t worry. Size isn’t everything.
Yes I have the Stock cable that came with my NAP 250DR. I was comparing this cable to the SNAIC 4 pin DIN I previously used between my NAIT XS2 and HICAP and was underwhelmed with the look of the thinner DIN TO XLR cable.
I was looking for an adapter to reuse my now redundant SNAIC 4 PIN DIN with my NAP 250dr
But All does sound fantastic now with my NAC 282, Hcap dr and NAP 250DR.
I may try a Chord Epic Din to XLR just out of curiosity.
Just for clarity, a Lavender cable is used to connect sources to preamps, so called because it’s a lavender colour. The 4 pin Din to XLR is not a Lavender, nor is it a Snaic. It’s simply a Din to XLR interconnect.
Very happy. More fine detail and a fuller, better focused sound. Bottom end has more weight but still tight and well defined.
But this is with my system and components, you may have a different experience. As always try to home demo the cable first on your system. Most dealers offer this with a small deposit.
