Hi, need some help please.
I currently run a Uniti Atom connected to a NAP 200.
I have an active sub woofer (MK AUDIO KX10) and i would like to try an connect it to my stereo system.
I have read that i can`t connect this sub woofer directly to the system and that i would need to connect directly to the speakers.
How on earth will i do that? is it even possible?
I did have Rel sub once, which connected to the Uniti Atom but it was messy
Hi thanks for your reply,
My speakers are not connected directly to the Uniti Atom as i have a NAP 200 Power amp, that drives the speakers, the uniti atom is just an interface.
My comment about i can`t connect to the Naim components itself comes from a forum i quote " For a Nap 250 and small speakers you want to use the speaker/high level input to sub. With the Nap 250 , or any other older Naim amp, you must connect sub at back of speakers - not back of the amp.
I have the NAP 200, so thought i couldn`t do it, i must confress i do love my audio but i am not an expert
I believe that as you are using the Atom as your pre amp then you can use the sub output on it. You could of course get a lead made up to use the high level (speaker) outputs of your amp but it may not be necessary. If you have a spare phono lead lying around it’s worth a try.
Your forum quote doesn’t make sense to me except that older Naim amps mostly didn’t have a sub output from the pre amp section.
