AirPlay/ Chromecast
Some help please. I use a Uniti Star & normally do all of my streaming via Airplay. My understanding is that as an iPhone & the star are both Airplay2 this is not up to CD standard.
I have also recently had Airplay dropping out.
Is Chromecast higher quality than Airplay & if so how do I set it up on the Star?
I use Apple Music because my main listening is to classical music & they seem to have the best library
This may help you decide
On an iPhone, there is no option to use Chromecast with Apple Music. It’s Airplay only.
This all sounds very straightforward, & Chromecast has detected my Star, but when I try to connect I get a message saying that Chrome can’t find Star on the network.
Both iPhone & Star ars using the same network
I have also tried with on line radio, but it’s a case that message showing that Chromecsst not detected. So saying that it doesn’t work with Applemusic doesn’t ring true.
I’m not at home to check if it can even be turned off or not, but is the Chromecast input in the Naim app settings for the Star enabled?
Hi facility to turn off. I am changing to an iohone16, see whether that makes a difference
