Airplay
Hi, how do i get my Muso QB to play via airplay? I can get it on my Muso, but it’s not picking up on QB. TIA
It should be exactly the same as on the Muso. What are you playing from? On my MacBook I get a list of relevant devices including Musov2 and Muso QBv1
Hi
I am trying to set it up from my i phone and i pad.
I can see the Muso in home, but it is not picking up the QB. There isn’t the airplay icon on the QB, so not sure if I need to somehow add this. I am a bit of a dinosaur!
What music app are you using on your phone? You should see all your Airplay compatible devices automatically listed in that app. No need to configure anything.
Hi
I am currently using the Focal & Naim, but it is only playing through the Muso. On my phone it comes up with airplay, but defaults to this rather than the QB and I cant work out why.
Hi Chris and Clive
I seem to have now sorted it, trial and error but also thanks for both of your input. I now have music playing through both units.
Thank you
