Hi forum,
my n-SUB iCom remote control has all of a sudden stopped working. I’ve tried new batteries, cleaning it, you name it. It’s not surprising really, every iCom remote i’ve had in the past has packed up in exactly the same way. Is there an alternative one that i can use?
Really appreciate any advice here. Thanks in advance.
Ok i’ve fixed it. Just went around with my Metcal solder iron and re-tapped every solder joint. All working fine now.
Richard can you please squash this thread?
Many thanks
It’s worth noting that if your n-Sub remote fails then there is one other alternative and that’s a Flash remote running with the last PIC chip which gives control of Naim AV kit as well as 2 channel.
