Hi all. Is it possible to use a preamp of another manufacturer with a supernait 2 ? I am looking at a used psaudio as I have made a good experience with their DAC
Yes you could, you would need an appropriate interconnect to either use the av input with the amp switched to av bypass on, or use the power amp in socket (revealed when the link plug is removed).
For simplicity I would use the av bypass.
