Amp To Amp
Hi all,
Strange question I suppose, but can someone confirm whether I can connect my SuperUniti to another amp? The ‘other’ amp does not havea power amp in facility but does have five fixed inputs. The SU has a pre-out and a Sub output and I was thinking of using that to the second amp.
You can use the pre out to connect to a second power amp. You can use the Speakers menu to select the internal/external outputs.
Thanks for your reply. The ‘other’ amp is an integrated amp and has five line in inputs and no power amp inputs, and you’ve just reminded me, the display has died on my SU so no can’t get to the setup menu🙄
In theory it’s not ideal to route the signal through two preamp, but it will still work as long as you can manage both volume controls.
If you can’t get the display replaced have you tried pointing your phone camera at the display in a dark room? Not ideal, but you might just about be able to see enough to navigate the menu.
