Annual Solar generation down 10% - Weather change?
She is right, anything over 70 quid is money for old rope. All they will do is clean the coils then run the unit at full power (cold and hot) and measure the temperature. You can do most of this yourself. The outdoor unit may be a bit more work if ladders are needed.
£7500 grant available on air source heat pumps as long as you get it installed, and signed off by a MCS approved firm.
Not sure how much longer these grants will be available, so if anyone is sitting on the fence, I would get it done sooner rather than later. I am in that line of work, and expecting the grant to go next year. If it does then that will basically kill the heat pump market over night.
Are you seeing the central heating do significantly less?
Phil
Yes, we normally turn off the central heating at night and then turn back on for a while in the morning. Now we do not need the central heating on until late afternoon or the evening. The overnight 5 hours of heat pump at 7p a kw gives us a nice 22 degrees set of rooms, having cavity wall insulation helps retain the heat during the day.
It’s a really good ECO solution for many people who are nervous about having an ASHP.
Phil
What weather change? :grin:
I thought it might be interesting to see how much energy I use now compared to before solar panels
So this is
Imported Electric energy+Imported+Gas energy+Solar energy used by the house
compared to
Imported Electric energy+Imported+Gas from 2018 (BS - Before Solar)
Surprisingly I am now using around 65% of the energy I used before solar. I would of course expect some reduction due to being more energy conscience but didn’t expect that much. Has anyone else reduced their KWh energy usage since going solar?
1.2Mwh for November to date..:sun::smiling_face_with_sunglasses:
1.22MWh exported in November.
No reason not to switch to pure class A power now :grin:
Even in peak UK summer I’ve only generated half that amount (in a single day)! Wow :smiling_face_with_sunglasses:
Ive yet to break 40 units.:frowning: in a day.
Our best was 46.1 on 3 July.
Today it’s 0.8 so far and it’s nearly midday!
I’ve updated our spreadsheet of power to include October and November. We are still in credit by £188, so fingers crossed that we see a bit of sun this month, and no freezing temperatures for days on end. It’s perhaps worth reiterating that this covers all our power, and charging our EV.
In a similar vein all but 43.37kWh of our electricity (1102 kWhs) was bought at 7p. We exported 285kWh and expect the reduction in surplus to be about £35 with a net cost of £60. The surplus was £402 at the beginning of November so lots of headroom for winter.
Phil
