Anyone use Ansuz power distributors or cables on the forum?
I recently took a punt on some s/h Ansuz Sparkz and like what they do to the system.
Nothing lost in terms of prat, but the music has softened a little - in a nice way. I don’t think I can hear the difference, but removing the units, I want to put them back on.
It changes the flow of the music for the better…
a topic on anzus on the old forum…
Found that topic. Looking at some of the ansuz prices makes the ND555/552/500 system seem like you’re slumming it.
The cables + distribution box can set you back a $100K or more.
there is no limit apparently. But anzus starts at 2k, seems very well constructed. You can ask Bertblue, he uses anzus.
yes Ansuz prices are scary and probably more than they should be, but power cables and especially power destributors brings a lot to your system. How far you should go up in the ansuz range depends on hfi-fi madness, and what other options you have to improve the system. This is the fantastic thing with a Naim system there are always many upgrade paths to better sound.
Claus
Yup, I was deep into Ansuz, Aavik and Raidho. Then I turned around and downsized all the way back to a Naim Nova. Now I can sleep at night knowing that I’ve gone back to making the music more important then the hardware.
My system now is the Nova feeding Harbeth 30.2 40th Anniversaries connected w/Super Lumina cables. One Ansuz DTC Power Chord about covered the cost.
I think it’s the most satisfying system I’ve owned in decades.
Bud
