Any Uniti Atom users here running Lyrion Music Server (LMS) with radio streams?
Is anyone here using a Uniti Atom together with Lyrion Music Server (LMS) for radio streams?
I’m seeing an issue where the Atom only displays the first ICY/StreamTitle metadata block correctly. After the initial track, the metadata never updates, even though LMS continues to send valid StreamTitle changes. The stream itself plays fine; the UI just remains stuck on the first track.
On Windows and Android LMS clients, the same stations update metadata normally, so the ICY blocks appear to be formatted correctly and delivered at the right intervals.
Has anyone confirmed whether Naim streamers fully support dynamic ICY metadata when the stream originates from LMS rather than a native radio provider? And if so, are there LMS settings, plugins, or workarounds that make the Atom refresh metadata properly?
Ron
Nobody ? :lying_face:
