Anyone else using a Naim AV2 with a Virgin 360 box?
It’s all been good for a long time now, but I still haven’t managed to code the Virgin remote to control volume on the AV2. Could it be because the AV2 isn’t connected by HDMI to the AV2? Please help!
Not a lot here have still the AV2. Maybe @Richard.Dane ?
I do still have my AV2, although it’s currently boxed up and unused. @vintageaxeman if you contact Naim support they should be able to give you the AV2 codes you will need.
I’m still using an AV2 with the Virgin 360 box but I don’t think you can use the Virgin remote to control the AV2s volume. I’m using an optical as I don’t think the AV2 has HDMI from what I can remember. It’s been that long since I stripped it all down I’ve completed forgotten. I just use the remote the AV2 came with for volume plus any other functions.
