We had a three-day outage here in Pittsburgh last winter and it got me thinking about how to keep the hi-fi usable when the grid goes down. I’m looking at home battery backup options for 2026, partly for the fridge and lights, but I’d also like the Naim stack to stay on without risking it. What I’m unsure about is whether these units output a clean enough sine wave and how they handle the inrush when the power amp wakes up. Some specs mention pure sine wave, but I don’t know how that translates in practice. I’d probably have an electrician wire a dedicated circuit rather than run extension leads. Has anyone here powered Naim gear from a home battery during an outage? I’d like to hear how it went and whether you used a transfer switch or something simpler. Any input from people who have actually done this would be welcome.
Just to keep a preamp, 300 amp, streamer going for 3x days would need around 10kW of battery storage. A UPS that size would cost a fortune.
If you install a home battery you’d need a transfer switch in the UK as it’s not permitted to feed power back to the grid during a power cut.
Most inverters made by good manufacturers supply a utility grade sine wave with distortion figures under load to match.
The inrush current is limited by the inverter not the battery, e.g my inverter has a current limit of 20A which could trip if I switch on a big naim amp, pre and streamer at the same time. It’s unlikely as the chances of that inrush all being in phase on the same AC cycle is low.
To be safe and unless you buy a beast of an inverter and battery I’d install a manual transfer switch so in the event of a power cut you can switch off the naim kit, manually activate the transfer switch and then turn the kit on one bit at a time to reduce inrush.
PS I don’t think there are any transfer switches that can do instant switchover, the switch itself might take a 100mS but they are normally around 2-3 secs in reality.
This thread is asking the same question:
