Hi,
I am thinking about buying a Sony WM1A DAP for portable audio to use with my Shure SE846 earphones.
Before I go down this route I noticed the LG V40 android phone with a 32-bit DAC and it’s audio apparently tuned by Meridian.
Has anyone tried the LG phone and know how it stacks up as a high quality portable audio device?
Thanks.
IIRC they reviewed the V30 in Stereophile and liked it (although they do get rather excited about anything that supports MQA) so that may be give you something to go on. You should find it with google.
