Just wondering if anyone here has much experience with T+A audio ?
Specifically the HV series. I’m seriously looking at the T+A P 3100 preamp. It’ll drive my ATC actives, not so sure the DAVE in front of it will be OK or not.
What’s the sound signature of this ?
I’ll say my DAVE and Chord Ultima Pre. 3 combo is dynamic and TBH after a certain SPL a bit too much of a good thing.
It’s quite relentless TBH and I’m after a more even handed preamp.
I had a home demo of an Octave HP300SE valve/solid state hybrid preamp.
Thought that easily seen off the Pre. 3 in a comparison over a weekend.
I’m thinking that the APM tone control/DSP room correction on the T+A P 3100 couldn’t hurt either as I change rooms or gear later on etc.
Although the Octave HP700SE with an optional tone control module fitted is roughly the same price as the T+A.
I preferred the T&A dac 200 direct into my ATC 40s compared to my TT2 through a 252. Don’t discount that, much cheaper option. Oh and give it a try with hq player upsampling to 512 dsd
I just bought a t+a dac200. It replaced my Holo Spring 3 dac and will probably also replace the Holo Serene preamp. I have it connected to the ATC SCM50ASL’s. I’m in the middle of comparing the integrated analog preamp of dac200 to the serene. Anyway, this is a great piece of kit and with HQPlayer DSD upsampling, you can make it really sing. Sounds great even without HQP.
