Would you like to elaborate as you seem to be making an accusation.
I’m not making any “accusation”, just a light-hearted reference that your success is considerably better than mine. Whenever there’s multiple possible answers, I seem to choose the “wrong” ones first more often than not. You have much better early success than me; perhaps you can choose my lottery numbers for me too.
Until recently, I had only 1 fail in nearly 200 goes (and that was a word that had 5 different options for the unknown letter after 4 green lights on the second guess). Just to mix it up a bit I changed my first word from “Stare” to “Adieu” but that led to another 2 fails in 5 days.
Having said that, I spend no more than a couple of minutes first thing in a morning, so maybe I need to devote more thinking time to improve my success.
So, not an “accusation” - probably just jealousy that you seem so good.
Apologies. I never use the same starting word. I can spend hours trying to work out the answer using pen and paper, using the incorrect letters eliminates a lot of possible combinations. It’s an elimination and probabilities game, it takes time and sometimes a little luck to work out. It’s something I enjoy doing and probably the only thing I am good at.
Wordle 418 3/6
Jolly good.
Wordle 418 4/6
Wordle 417 5/6
Wordle 418 4/6*
After a 6 yesterday I knew I had to perform better today…
Wordle 418 3/6
Aw, shucks.
Wordle 418 5/6
A miserable 5 here
Wordle 418 4/6
Wordle 418 4/6
I don’t think I’ve ever had all the right letters in all the wrong places before!
Wordle 418 4/6
Wordle 418 5/6
Is it too late for GCHQ, John?!
Wordle 418 4/6
Unfortunately I cannot answer that question
I reckon your line three would have been a much better solution
Wordle 418 4/6
