Hi All,
Using NDX2 into NAC252. When using the app (Apple), I’d prefer to use the volume slider. Changing the preference in the app doesn’t do anything and I just get left with the + & - buttons.
Anybody else experienced this and solved it?
Hi All,
You cannot get the slider when you are using system automation into a 252. The app has no idea where the volume is set, so it cannot work.
Thank you!!
Nigel, thank you, that has perplexed for ages!
