Hi there ! Hope you’re fine.
I have an issue with streaming AirPlay from my IPhone or iPad. Whenever I start airplaying from Apple Music it starts but after few seconds stops playing. When switching to iPhone it is keep on playing and then to uniti again it plays and stops again. Like it freezes. Has anyone else noticed similar issues? @Stevesky any idea ? I have newest iOS. iPhone 17 pro. I thought it is a matter of some updates, changed phone, updated iOS but still the same. Drops connection. After several connecting and disconnecting it plays fine but it is pain in the …
You have to remove the codling moth larvae first.
Being more serious, I see you opened the same thread in August. Does it mean it was ok in that period or still there?
Maybe @davidhendon to help.
Have you tried restarting your Atom ?
Yes I did open. I thought on new phone and new iOS 26 problem will be solved but it is not. I’ve been waiting for system refresh on Apple side. It’s strange because it is so unstable. Today I have checked ipv4 only as someone advised and it was ok. But I know that in few days problem appears again (I hope not). Generally communication between iOS and Naim is so-so. Try to make volume up, it reacts with lags very often.
So summing up, for now it is ok but I will try again tomorrow.
So after few days of testing it works now so far
yeah ! I believe this ipv4 something, made a difference.
Fingers crossed!
Possibly, there’s something in your network setup to be cleaned up, but if it is stable for you now, maybe it’s not worth checking. (Myself, and I guess others, have my Naim boxes running fine with both IPv4+6 running in my LAN/WiFi. But then, there’s potentially so many things to check and that can differ in setup.)
