How easy is it to correct inaccuracies in metadata and/or album track information in Asset?
ATB, J
ATB, J
I have Asset installed on a Synology NAS with most files in FLAC format. I use MP3Tag on a Windows PC to correct metadata information and find it easy to use.
dbpoweramp works very well for me
Asset is irrelevant, it is a case of finding the software you like to edit metadata.
Bruce
Asset just uses whatever is encoded into the FLAC files. I also use MP3Tag to edit metadata if necessary.
Thanks all
ATB, J
Give mp3tag a go.
It can download metadata from multiple sources.
Agreed - dbpoweramp makes changing metadata really easy.
I find Metadatics most useful fot the tag editing I do, but it’s Mac only.
Roger
Metadatics too. Easy to use and very flexible
Long-time mp3tag user here, for ease of use.
Sometimes dBpoweramp editing function is needed, to see all metadata field being used, and sometimes to fix those that mp3tag is having a problem with.
Anybody on Linux, MusicBrainz Picard is recommended.
Dead easy to use, nice GUI and simple to do mass tag updates over an entire library.
Been using it for a few years now.
It also handles all the tags for multi CD set rips correctly, which some tools don’t.
