I currently have some ATC SCM 20’s (passive) on loan and thought I would give them their own thread!
The backstory is I had become a little frustrated with my 40a’s, they go from sounding great to fatiguing and I have been faffing around with positioning and sub settings for too long so I arranged a demo of some stand mounts to see if the root cause of my issues was overdriving the room with floor standers.
Tony at Basicaly sound arrived with the 20’s and a nap250(NC) as I no longer have a power amp given my system has active 40’s.
We played a couple of tracks on my current system to get our ears in (40a’s with 552/NDS/555DR) and it was having an off day and Tony picked up on it straight away. Transpires they have an intermittent fault… they are now back at ATC for fixing…. In someways a relief as I thought I was loosing my marbles!
First things first the NC 250 looks very slick in my rack and makes the green lights of existing boxes look a bit dated - well done Naim, very classy looking…
The 20’a are also a lovely looking classic speaker and very easy in the eye in walnut. After plumbing them in they sounded great, all the ATC attributes but…. Being driven passively and not benefiting from a full cabinet I felt they were lacking compared to the active 40’s and 20’s I had previously tried.
Having had them for 2 weeks the combo has really grown on me, yes a little bottom end missing compared to active/full cabinet but sounding wonderful none the less. Not sure if the improvement was “burn in” or my ears adjusting to a passive presentation….
The pairing of the 20’s and the 250 is c£10k, the same price as active 20’s and whilst I think I would choose the active presentation I can see why some would chose the passive - really good speakers in my set up.
The 20’s are supported by a pair of rels and they add a depth that I really like but they sound good without them.
I am down a path now so will try some 50’s and then 20’s again versus my 40’s.I already know I prefer the 20s to the 40’s so a change will likely happen be it 20’s or 50’s
I also noted in my room ATC’s work well at low volumes, nothing to compare them too but many comments suggest they don’t sound as good at low volumes, yes they come alive with volume but all the emotion is there at low volumes.
If stand mounts work for you then I would definitely have the 20’s on your list to consider.
Gary
