Hi guys… Im new on the forum… I’ve read a lot of posts with similar questions but not the same and still can’t get a response.
I currently own a Uniti Atom (as pre) with an 250DR and a PMC Twenty5.24.
I know that I’m not getting the best of the 250, but the question is… based on your experience, a Nova and the Pmc should sound better than my actual configuration?
Here I can’t get the nova to try it out… neither have an 272 available to try or buy…
I don’t wan’t to spend much more money on 282/Hicap/Ndx, so the thing is should i keep the actual (atom + 250) or trade the two boxes for a Nova. Always keeping the PMC… at least for a while.
Thank you for your advices… and by the way I’m just an amateur on audio things.
3 years ago i compared the atom and the star and decided for the star because of the better sound. now i have compared the star with the nova and the nova is Nine my main system. i still had a few sound problems with the nova, but now they seem to have been resolved with the naca5 cables. the step from atom to nova is significant for me. i don’t know the difference between atom and atom + 250dr. I will soon get the 250.2 to try out with the Nova. then i can say something about how a nap on a uniti changes the sound. the best thing to do is listen to a nova sample.
I just added the 250DR to the Nova and the uplift is astounding, seems now a better match for my ATC40.
All I can say is it works in my environment, main variable as ever is now the recording quality of the source stream, this has become if anything more noticable.
I wonder which of the 2 boxes I should connect with the 1 Naim Powerline I own.
Nova definitely did not reach ATC SCM40 in bass department and midrange except at much higher volumes. Not sure I can advise on your speakers. I initially misread your post, really not sure you will do better with Nova alone instead of what you got.
