Hi All,
I believe this has been discussed a while ago but i do really need your help here…
I’ve got HANA EL (low-output MC cartridge) on my RP6 turntable which is connected to my Pro-Ject Tube Box S2 and set to 470Ohms, 60Db gain.
However, i was wondering what should be a correct sensitivity input settings on my Atom?
Currently it is set to Hi-Fi (2.5V). Can anyone please advise me if this is the right setting for this setup or i should switch to 0,5V?
Many thanks in advance
A.
