Anyone with any experience with the above - views would be appreciated
I have Focal ClearMG which I love but need closed back for listening in family lounge.
John
John
Boring reply, the one I give in every headphone thread.
Headphones are very, very personal. Not just very different sound character but in terms of fit and comfort. If one or both doesn’t suit then they are a wasted purchase. Buying without trying is, in my view, risky. Secondhand is sometimes a way to minimise this.
Note that open v closed do tend to sound quite different whatever you pick.
As for your specifics I have heard several Focal and Sennheiser models but neither yours or the one you are considering. I didn’t really like any of them but from what I have heard from the two brands they have some similarities with an emphasis on soundstage and dynamics, a rather technical sound perhaps over a smoother ‘flow’ and musicality from other manufacturers (like ZMF for instance). They are popular, just not for me. That’s my opinion, but don’t take my word for it. Get a demo or a pair to try at home.
Bruce
I didn’t get on at all with the 820 closed back - the bass had a very odd sound to it.
As above headphones are personal but I would counsel against buying blind as comfort and sound are very individual.
I got them on a super deal from Richer sounds but returned them. I ended up with hifiman Arya organic which I love. (But they are open back)
I also didn’t like the 820 closed back headphones completely different to the non closed ones.
But most of the sennheiser range like a amplifier that can add some weight and warmth to it, without removing any of the details and space you get with them.
I have the Senn 820’s. I tried them with an Atom HE and couldn’t get on with them. I switched to the Senn HDV820 amps, with a Wiim streamer on the front and they are great.
Very personal things though.
They were bass light and (in my case) they sounded perfect if I held them onto my head slightly. Seems others have had the issue with clamping force. I found a 3D printable bridge for them that sits over the headband to increase the clamping force (I must have a small head). And they now work wonderfully well!
