Is it possible to use attenuation between the pre and power amps on a supernait 3? (Without taking it to bits).
be easier to attenuate the input with rothwell or similair.
Attenuate the source input.
Attenuating between pre & power would be an unortherised mod, meaning it can’t be discussed on the forum
Does it help if you move the PMCs further away from the wall?
