Hello, I am thinking I pursache an audioquest rocket 33,bi-wired, to use with my naim nait xs and proac tablette 8.
Someone knows if, could works fine? Thank you very much.
I would definitely not recommend bi-wiring from any Naim amplifier.
Have a read through the FAQ here on speaker cable and Naim.
Audioquest cable is normally spiralled inside, this makes for low inductance and high capacitance. Kind of the opposite what your naim wants to see. I unloaded my AQ midnight 2 runs when I got a NAIT 5si. If you don’t feel the urge to pay £30/m for NACA5 (I didn’t) linn k20 works fine at £5/m with the correct properties. Don’t bi wire!
OK thank you very much for the advice.
And could I use jumpers,?
The Rocket 33 isn’t spiralled inside, but my experience of it wasn’t positive when I heard it. You can get much better for the money.
I’ve given no detail as it was an “ugh, take it away” type of sound to me - nothing really right - lasted less than a minute on demo. Audioquest do much better, as do many others for the same, or lower price.
