Just got a hold of a Wireworld Supernova 7 glass optical cable to compare it to the QED Performance (plastic). I wasn’t expecting much difference as I felt that optical were pretty much the same… it would appear I was wrong.
The sound is fuller in the the lower end but without making it feel muddy… in fact, it seems like a big improvement in clarity. Normally if I was to hear more detail with a BNC cable, it would often mean extra noise getting in and I was hearing was false detail. The soundstage and imaging is improved, more depth… maybe slightly narrower but definitely more depth and height. Notes, instruments seem to have a more distinct edge to them and better resonance, timbre. Very realistic sound, natural with impressive clarity and detail.
Now for the bad/negative side. The cable is noticeably more heavy, thicker (compared to the QED) and if the cable hangs straight down from the back of the Chord Qutest, it pulls the plug out of alignment. There seems to be more play with the plug even after it’s pushed right in. The plug in the Auralic Aries G1 is more anchored but still has a bit of movement. This had no affect right until I reached 24/192 where you would get dropouts or, no sound at all.
After a quick call to the tech guys at the place I bought it from, they advised it isn’t uncommon but it can be resolved by simply moving the device further onto the shelf and provide some support to the back of the cable.
I had some kayak foam that can be easily shaped so I made a little block with a V shape cut out in it to grip the cable and hold it straight… bingo, problem solved. I guess it wouldn’t a problem at all if more of the cable was support by the shelf but a little bit of support resolved it.
Is it worth the effort? Definitely, I did not want to send this cable back, it really was a superb finishing touch to my system.
The Aries G1 is now mine. It turns out the demo unit was only 10 days old… an order that didn’t go through. So, 1st registered keeper, full warranty and a couple of hundred saved off the RRP. Very happy. Loving the extra control, screen and being able to use the Naim remote to control it and of course, amazing sound quality. Happy days!
