I’m currently using a SuperNait 3 in my main system while my 552 is on holiday in Salisbury. I plugged the ND555 into the streamer socket, the NAT01 into the tuner socket and the LP12 (Urika) into the CD socket. Now, if I’m listening to the tuner and select ‘play’ on my iPad for a track on the streamer, it automatically switches inputs from the tuner, but not to the streamer input, instead to the CD socket, to which is connected the turntable.
Input switching can be set up by selecting ‘pre’ on the remote, pressing and holding the ‘prog’ button until the LED in the volume knob flashes and then pressing the ‘mute’ button. Repeat presses on the mute button goes through a sequence of illuminated pairs (or three) of input selector buttons. Once the desired pair is illuminated, you press ‘prog’ again and the new setting should be stored.
Logically it would seem that I need ‘tuner’ and ‘stream’ input selector buttons to be paired if I want auto switching between tuner and streamer. However, no matter which group of LEDs I select, I cannot get it to do anything other than as described above, that is to switch to the ‘CD’ input, although music is being delivered to the ‘stream’ input.
Since it’s only a temporary arrangement, I have swapped the LP12 and ND555 plugs over so that the streamer is plugged into the CD input and the turntable in the stream input. It’s not a big issue, but has anyone been able to work it out and could explain how to do it?
