Balance control on NAC332
How do you know when you are exactly in the centre when using the balance control via the remote apart from your ears? The volume changes show as a number on the NSS333 display but nothing when using the balance.
The volume knob indicator light on the 332 moves left or right when you adjust the balance. It’s easier to see with the brightness turned up
Many thanks @nicnaim , that works a treat!
