Want to get a 3 meter run of balanced cable for my Focal headphones. I got a single run with my Clear Mg, but having two Atom HE’s in house and considering the location of the XLR connection I’d like to get one I can plug into the second HE and leave there.
But I seem to find very few options online. Any idea where one can find cables that fit Focal? Even on the Focal website I can’t find any.
Also is there a preference for XLR or Pentaconn? Pentaconn would be easier to jack into the Atom HE I have downstairs.
Yep. Plenty of options for colours of cables. And connectors for your amp. I use my Clears with a Violectric V281 balanced. My cables are 3m, but I think next time I’d go a bit longer. I do have the 5m single ended coiled cable the Clear Pros came with though.
Then the question of XLR vs Pentaconn. My expectation would be that both would yield very similar results.
Actually Pentaconn could be the better option for me if quality similar. I have the XLR that came with my Clear Mg. So that would mean I could connect my Celestee balanced at the same time.
