Probably an old question here, what’s the issue with Radio on my 272 not playing, not a station I use much, but her in doors would like it?
When was the last time you used it? Remove the favourite and add it back in, the stream addresses for the bbc changed a while back.
BBC changed their addresses - and you need to reprogram - and yes it has popped up once or twice
Deleted and re listed, sorted now, many thanks.
